Any idea why Renault changed the design from press-on to splines with circlips? Just curious.Interesting question. Renault gearboxes pre NG series required press on gears. NG series gears, bearings, synchros, etc. slide on splines and are retained with circlips. I would generally agree that street boxes are not disassembled regularly therefore the press on design, but it isn't necessary.
OK, here's a pic:
The hub is item # 58, and the bearing is #55.[ The bearings are retained by items # 52, 59 and 62. Pretty cool, eh?]
Have you driven both? Any noticeable differences in terms of noise?
Yes, but regarding street gearboxes, what is the reason behind using press fit gears on the shafts?
