Engine / gearbox sandwich plate.
Help please, what is the set up on the Mk1 race cars ? The Parts catalogue shows a lower plate. (part No 1)
Is there an upper part to this, I cannot find one, so does the bellhousing bolt direct to the engine ?
Thanks, Peter.
Thanks, Peter.
Going by that drawing it would appear that a sandwich plate is not used. I hope the #1 plate is doweled to the bell housing as it index's the starter to ring gear engagement dimension which is fairly critical.
Brian Stewart
There is no upper part to plate 1. It is essentially a cover plate to close off the bottom of the bellhousing.
Doc Watson
I have just assembled a 'dry fit' of my engine so I can check the fit of the lower bell housing to my chassis..... my cover plate covers the whole bell housing..... there is even a vid.....
17 mins 19 secs it makes an appearance......
It still needs a vent hole in the bottom to pick up air when running and it will be ss mesh same as the top and bottom cover plates. It does mean that the gearbox is 2mm further back due to the plate being between the engine and bell housing.
what's the accepted wisdom with regards to venting on the bottom? I just made a solid block-off cover and fitted it, I want to make sure any random oil drips from the bottom of the engine don't their way into the friction surfaces of the clutch and flywheel. The Porsche bell housing has an opening on the side to vent, though it probably won't feed fresh air to the clutch.
Hi Andy, I have "liked" your video, It did make me check what the original set up was, hence the question above.
I have seen the cover plate on the Cushman site. but I think it is easy to make.
Thanks Peter
Doc Watson
I think some form of venting is desirable, if you have a vent on the cover plate and also one on the top of the bell housing then it will allow the air to flow freely even if the bottom bell housing plate is 'solid'.
I think Safir make a bell housing with a cast in duct to 'scoop' air into the clutch area... trying to find a photo if it.
Hi Tom. Just additional cooling I guess,
regards, peter.
Doc Watson
here it is....
the scoop is at the top of the bell housing.
Andy, I have the Safire Bell housing, Thanks, Peter.
here it is....
Hi Andy, Yes that is the one, I cut off the casting at the top to put in a similar vent to the bottom. Thanks, Peter
here it is....
PS , Andy, It is not a scoop at the top, just a casting with GT40 on it. It was cut off by the Gentleman who sold me the casting, I worked on it to put the top vent in. Regards, Peter.
Hi, This is another shot of my Safir Bell housing, note arrows pointing to 2 small threaded holes. To hold the cover plate I guess.
Also 2 large 1/2" holes at the bottom. No sure what these are for . Brian's cover plate photos above shows the right hole. The other seems to be redundant.
Jac Mac's post suggests indexing, and Brian's photo show the right hand bolt but it is not clear what the detail is.
Comments ?
Regards Peter
JimmyMac
Dry sump 260 / 289 ?
I have always thought that those holes in these newer castings were redundant detailing off the original ZF 4-bolt bell housing 7/5351 which was used in the days of the DOHC 255 engine and this had a full length and width alloy dry sump. The casting has two screw holes at the bottom of the rear end.
The Hewland bell housing for the 255 engine has a similar two holes.
Then again I am assuming the other bolts holes on both engines had the same geometry !
Dave Bilyk
Dave Bilyk
Hi Andy, I just enjoyed your videos and it was good to see the man behind the story. Regarding your comments on steel versus alloy timing cover, you might like to see the weights that I measured when I changed mine. Look forward to the next video.
Iron Al Saving
Heads 2 x 26.4 2 x 13.5 25.8
Manifold 18.6 8.3 10.3
Timing Case 6.4 1.5 4.9
Total 77.8 36.8 41
Dave
