I'm at the point of doing some wiring and would like to run this by you guys. I will be using two separate switches on the dash to turn the fuel pumps on (grounding the infinity mastercell with the switches). In order to incorporate an inertia cut off I thought I could use it as the chassis ground to the switches. In effect cutting ground to the switch/ master cell in an accident.
