Installing the Drop Gears...
I bought a set of John's gears a while back and put them in this week. I posted about this on the FB group ("Superlite SL-C Owners & Builders" for any
Owners or Builders that want to join). Figured I'd include my comments and thoughts here since a lot more will probably see it here (hopefully without my phone typos).
My trans is a V10 unit. There is LOTs of clearance for these gears in the V10 case - no machining is necessary. V8 guys, YMMV. Pictures shows where these gears sit in the case to demonstrate.
If you do it yourself, expect 8 hours once you have it drained and on the bench if you really take your time. You will need 32/34/36mm sockets, some drifts/punches and one special tool (Audi T40210) or you can make one. I welded one up, but you could probably grind one out of the correct sized impact socket. You will also WANT a real 1/2" drive impact to remove the shaft nuts. And you will need a couple short 2x4 blocks or something to sit the trans on since the input shaft sticks out. If you are pulling the front drive, you need E-ring pliers and something to plug the hole.
You don't need the rest of the special tools in the manual and you do not have to disassemble the gear stack. The gear stack is heavy, so you may or may not need a hand lifting it out and putting it back in (the manual shows a special plate and a shop crane, but I did it by hand by myself with no issue).
I did not start with the manual, but did pause when I got to the point where you have to get the pinion out. Found the manual (attached here), and sure enough, you have to beat it out. The manual is not ideal because it covers way more than what you want, and has no complete parts picture for the trans. But all you need is there as long as you take pictures as you disassemble, or lay the parts out methodically.
A comment on John's gears...
I don’t know John other than buying the gears from him and I’m not a mechanical engineer. But we have been racing for a long time and do most our own work, so I've seen plenty. Given that background, take this however you want...
The OEM gears are such that at times only one tooth is taking the pressure. John’s are the same. However, John’s gears have a heavier root and a shape that keeps the tooth thicker until the next tooth engages. IMHO, materials and hardening being the same, I believe John’s gears are stronger. Given the fit and finish is miles better than OEM, likely the material and hardening surpasses OEM as well.
I've include pictures of both sets of gears together. You can see the tooth shape and size, as well as the rough edges (failures waiting to happen) on the OEM gears and the much better finish of John's. John's gears also fit better on the shafts - that is they were tighter but still went on by hand.
The attached pictures are LARGE so that folks can see the details on the gears.
I am going to try to attach the manual, but not sure it will let me as it's 11MB and it's a PDF
Frank
Fit in case
Old vs New
