GT40 build – sourcing Porsche G50 / equivalent heavy-duty transaxle (V8 application)
I am in the UK and looking for a transaxle for a GT40 replica build my son is doing in Australia.
The application is a mid-mounted V8 (high torque), and the requirements are:
  • Must be suitable for ~500+ hp / high torque V8 use
  • Limited slip differential required (factory or uprated)
  • Strong preference for Porsche G50 family, ideally G50/52
  • Alternatives considered: Audi 01E or Graziano V10 transaxle if appropriate
  • Road + occasional track use (not full race sequential required)
  • Reliability and parts availability are important considerations
  • Will consider rebuilt, exchange, or core units
We are aware that:
  • ZF units are now rare and prohibitively expensive
  • G50/52 is preferred due to strength and LSD availability
  • Graziano and Audi R8 units are alternatives but require adaptation
  • Spares for Graziano in Australia are limited so this may be an issue
While the g50 is the preference, a g86 or g96 may also be fine
We are based in the UK and will arrange international shipping to Australia if required.
If you have:
  • Any available G50/52 cores or rebuilt units
  • Knowledge of current availability through your network
  • Or can recommend a builder with stock
I would appreciate your guidance.
I am not sure a Quaife ZF will handle 500bhp high torque.
A genuine GT40 ZF or Pantera ZF nor an RBT ZF will not for sure (as they where not intended to).
Mike Pass
Go with the G50. One of our NW guys has had one behind his 428ci stroked Windsor 351 with 500 ft.lbs torque for over 20 years and been fine. A few clutches gone but no issues with the G50.
Hi robin also es ist so : da reicht ein g50/00 oder 03 das 52 ist nur teuer meine lola hat einen chevy motor 6.1 cci mit 580 ps ich habe ein g50 /00 mit nachgegüsten sperre eingebaut du brauchst dafür eine adapterplatte und eine verstärkte andruckplatte stage 2 von kennedy und es gibt eine dickere kupplungsscheibe von sachs mein motor hat 680 nm das audi getriebe ist nicht geeignet für euer vorhaben leider gibt es keinen verkürzten 1 gang bei der übersetzung für das getriebe
I run a Porsche G50/01 in my black Mirage- about 620 BHP.
G50 reliability/ high power ? WHAT TIRES?????? Street tires on the street maybe..... the tires will just spin and preserve the ring and pinion. BUT add grip and this becomes the main issue with the G50s. The small ring and pinion cannot live with high power AND full grip (no tire spin).
I would look for a 996 turbo 6 speed. It has a 9 incn R&P and is a more modern GRBX overall.
Or limit the engine power to about 400-425HP, run street tires and then you would more than likely be Ok with a G50.
also ich fahre die breiten pirelli reifen in 15 zoll für die straße
Hi, this comes up every time a question like this is asked. If you have high torque and 500+ HP you are not going to need 5 gears, and the Porsche 930 4-speed with LSD fitted comes into focus. I run one in my McLaren M1 replica with 440 hilborn injected chev at around 600hp at 6300 and torquey as hell. 4th gear is tall enough for cruising, 2-3 is the fun zone, 2 is just inside the traction threshold. Just a thought. Cheers, Andrew
Call Rodger at California Motorsports. Be aware that this is a 100% best pracice/ higest quality workmanship and QA shop that only works on Porsche Transaxles. Much of their work is refreshing gearboxes in race cars. There are no cheap shortcuts to be had. Rodger won't do them. Also a bit of advice. If you want to use a 50-52 for example, then have them source the core for you. If you bring them a unusable core your have bought on ebay then the wasted money will be yours.
I have no financial interest in CMS
Rodger, CMS 928-855-5755
