Intake losses
Hi all, got a bit bored today and did a science experiment measuring intake system losses with filters off and on - this was because I'd observed some losses in previous datalogging and I wanted to verify which part of the system was contributing and by how much. Engine is a cammed LS3, induction is EFI 50mm ITBs, test procedure was a quick look for the plod followed by a WOT run from 3k to 6.8k in second gear, which is about 37-92mph. ITBs are fully sync'd and fully opening. I thought the results might be of general interest.
#1 - Filters on, atmospheric reading (Baro) 95.2KPa, Wide open MAP reading 93KPa @ 3k rpm, 88KPa @ 6.8k rpm
#2 - No filters, atmospheric reading (Baro) 95.2KPa, Wide open MAP reading 93KPa @ 3k rpm, 89KPa @ 6.8k rpm
Conclusion: The restriction is reasonably significant (about 4-5%) and is mostly in the intake system itself. 50mm ITBs appear about tapped out at 500-525hp. Upside is punchy/torquey mid range.
Hope all is well!
Cheers, Andrew
Brian
I like hard data like this. You're filters are a lot less restrictive than what many put on IBTs trying to look cool.
I think you would be hard pressed to not see 5% below theoretical. And truth is, even with a little manifold vacuum, if you have the right length runners for the RPM, you can still get better than 100% VE.
You may be interested in this too!
