SL-C Progress-Week Ending 09-27-2013:
We fitted the center section of the body ( about a half a dozen times) onto the chassis (pics. 001, 002, & 003) to make necessary cuts for stand-off's, brake fittings, coolant hoses, etc.
My back ordered Graziano braces and shifter/cable bracket arrived. Here's a couple of heads-up for you Graziano builders just now receiving there parts.
FYI Graziano support braces:
FYI Graziano cable linkage bracket:
I also just received the back ordered clutch and fly wheel for the Graziano but can't do any thing with it until Fran gets me the rest of the missing Graziano parts. I can just imagine how much fun that will be without any instructions!
I have to walk away form this project for about a week to regain my sanity; other wise I might do something rational....like burn it!:rifle: This just isn't turning out to be the fun project that I was so looking forward to!
Talk to you all in about a week. Better luck with your builds!
Jim
- All these months of staring at the Graziano I never realized that the Graziano is off-set and not centered. Therefore, the braces are not the same length. The longer arm goes on the drivers side (ask me how long it to figure that one out). That little piece of info should save you so time.
- The 4 bolts on the gear box bracket are symmetrical; so that means it could bolt up any of four different ways. Again, having never seen a Graziano and not having a manual, I guessed wrong a couple of times; (see pics. in post #97 for the correct orientation) and I still guessed wrong about which side the support brace went...inside or out side!
- The 3 mounting bolt you will need are 8mmX20mmX1.25 pitch.
- The holes on the bracket do not line up with the tapped holes on the Graziano; therefore, they must me enlarged.
Jim
