Jim, to piggyback on what Chuck said, I used a plumb bob to locate my new mounting points once I determined where my steering shaft should be. For me, it was centered between the clutch and brake pedal, then centered to the dash. This change required the spherical bearing to be mounted about 3/4" away from the factory hole and spaced up as high as it would go. This brings the u-joint pinch bolt head real close to the frame, but I prefer my steering wheel to sit a little lower.
Probably best to locate where you want your pedals and have the dash in it's final position FIRST before you drill your new hole for the spherical and flanged bearings.
The flanged bearing behind the dash had to be relocated so it's centered with the dash steering cutout.
After this change, the steering wheel is now perpendicular to the centerline of the car, not angled off to the left when viewed from above, and it's centered in the dash.
Tom, Thanks for the idea and photos! I'm heading back out in the garage now....
@Fran - Thanks for your reply. I did check out the online manual, good photo documentation. It helped me figure out how the mount is attached at the dash with the servo thing... I knew I was going to get called out on my terminology with my previous post!
