LSA SLC Build Log
My big feet and the power column just didn't want to share the same space.
I am going to run a full manual column. So the one that came with my car is up for grabs if some one needs it !
GM VSS sensor mounted !
Small shields to keep some of the radiant heat off the trans.
Installed the two variable speed fan controllers, and the control relay boxes for the lift system. The uncovered portion of harness is for the front lights and will be finished after the body is mounted.
Well I've been off line for a while ... but made some progress !!
Heat exchangers for the supercharger.
