I am making a Monocouque from scratch, it is an alloy, riveted, bonded arrangement for a single seater, and so to my problem.
I started by using 5052 - T32, all was going along ok until i started to rivet the tub together, the rivits bunched up the alloy and squashed the alloy out from beneath them, resulting in a very much less than profesional finish.
After a bit of searching on the net a solution was found, 2024 T3. A sample riveting proved my therory the 5052 was soft, but the next problem was I couldn't bent the 2024 tight enough and it will crack along the bend without warning, once again not a happy situation.
I spoke to a bloke who builds cars and he sugested 5251, the local aircraft factory sugested 6061, the local fabricator said 5083 there is a new(ish) product 6013 and I am confused
Are any of you wonderful people from the racing industry in the 70's and what would the material of choice have been. The style of chassis is along the line of the Lola T332.
Thanks for you anticipated help
