Our T70 is coming along really well and I’ve been quite pleased with the progress we’ve been making. The only thing about the setup that bothered me, and more than a few other 930 transaxle users, is the half shaft angle. It will typically be between 10-15 degrees with an inverted 930 (unless you dry sump your engine and run extremely low ground clearance) and 10-15 degrees seems excessive for a CV joint to be fixed at indefinitely.
I spoke with a few companies about the CVs and angle but there aren’t many of them with direct experience with the setup. My mistake might have been talking with transaxle companies when I would have been better served asking around the sand rail companies. At any rate, I contacted Kartech (http://www.kartek.com/), a California shop that specialized in off road race trucks and buggies. I explained my intended usage and what I was concerned about:
However, they do offer uprated cages for the CV joints that have elliptical openings and will not bind up with angles up to 28-30 degrees. These cages replace the stock cages, are not as brittle and are relatively inexpensive at around $75 each. And, for the CV boots, they also offer a number of “double boot” systems for 930 CVs. These are so that a thick outer boot that will protect the relatively fragile inner boot so that heat and debris doesn’t rupture the boot that contains the grease.
So I ordered up some new cages and additional boots to have on hand if we wish to install them. Also some CV bolts with head holes for safety wire. We have a test day coming up on the 17<sup>th</sup> of this month and I won’t get them in before then, but maybe shortly after for the following track day.
Just thought the info might be interesting for some of the 930 users that aren’t dry sumped and/or ring gear flipped.
R
- Angle being too high, premature CV failure
- Due to high angle the CV boots would rupture, leaking grease, and causing a failure
R
