Has anyone seen a master cylinder that is remotely mounted with a booster and pressurized by another master cylinder controlled by the peddle
System works as follows
master cylinder 1 creates pressure from pedal
master cylinder 2 receive pressure with a booster to the front brakes
the setup requires to master cylinders on the brake pedal
and two remote master cylinders with boosters, separate systems for front and rear
this would ease the space issue with install a dual cylinder and a booster
in such tight quarters
LLoyd
LLoyd
