S2's Build Thread
Scott
I was leaning towards Performance White on the headers, but I decided to go with Performance Graphite. It matches my color scheme better and it will be less likely to show wear.
Zirocotec ThermoHold Performance Graphite
The catalytic converter assemblies will generate a lot of heat so I had Zircotec cover them with ZircoFlex SHIELD. The assemblies were; (1) plasma-sprayed with ThermoHold Performance White, (2) wrapped in fiber insulation and (3) enclosed in a hand-formed and welded 0.1 mm thick shield. This is the same process that they use on F1 cars and the workmanship, particularly on such a thin material, is outstanding. Unlike other dimpled materials that I’ve tried, you can easily handle the assemblies without denting the covering. All of this comes in at a price. Covering the small catalytic convertor assemblies cost more than double the cost to coat he headers and merge collectors.
The welds are craftsmanship are spot on
ThermoHold Performance Graphite on the headers and merge collectors; ThermoHold Performance White, fiber blanket and ZircoFlex SHIELD on the catalytic converter assemblies; and ThermoHold Performance Yellow Gold on the heatshield
Given that the engine is out, the next step is to fabricate a heat shield between the cross-under tubes and the dry sump.
Good choice Scott! It’s looking really good!
I like the white too, but one little problem / oil spill and they look like heck…
Scott
When I made the initial decision to run E85 I was aware that everything in the fuel system needed to be E85 compatible and that I needed to add an ethanol content sensor. I subsequentially learned that E85 contains 40% less BTUs than gas which means that the system must flow more. Since E85 is 85% ethanol and 15% gas that equates to (0.85*1.40) + (0.15*1.00) = 1.34 or 34% more volume. E85 also increases power, so the Wide-Open-Throttle (WOT) demand is even higher. Based on this information, I upgraded the low-pressure pump and chose an appropriate high-pressure pump. Problem solved, right? Nope.
What I failed to intuit is that what goes in must come out through the fuel injectors so I need to upgrade them. Everyone that I spoke with recommended the Injector Dynamics ID1700x for my application. The tuners love them because they supply accurate detailed data which simplifies their job and results in excellent tunes. Apparently one supplier stole their data, fudged it and presented it as their own (thread here).
While other suppliers modify stock Bosch injectors, Injector Dynamics is the only aftermarket supplier to have earned Bosch’s Authorized Technical Partner status under which Bosch Motorsport manufactures Injector Dynamics’ proprietary design. Injector Dynamics then breaks them in for a few hours and groups them into matched sets.
They’re very trick, but at $300+ a pop a set costs almost a quarter of a fully-dressed LS3 crate engine. That said, the upgrade was simple. I just removed the fuel rails, lubricated the O-rings with WD40 and popped them in.
OEM fuel injector (left) and Injector Dynamics ID1700x (right)
I’m not crazy about the purple aluminum bodies, but unless you shine a light on them they aren’t all that noticeable
that aluminum sleeve is removable on other ID injectors. Maybe you can swap out the sleeves for different ones or remove the anodizing from the sleeve for a bare aluminum look.
Ken Roberts
You can remove the anodizing with Easy Off oven cleaner. I would carefully mask off the other sections of the injector with aluminum tape first.
Thanks for doing such a detailed writeup, Scott.
I'm really appreciating the depth you've been going to with all the writeups you've been doing for this project, it's been an enlightening weekend read.
Seeing references to other builds and how everyone is chiming in with how they did things, is really awesome. It's an amazing level of collaboration.
The depth of your 'Well, the SLC could be 20% more awesome.' mods is inspiring. Also seeing how your home shop has grown with the tools needed for the project along the way, instead of 'I already had this. Might as well use it.' Esp your dabbling into the 3d printed carbon reinforced realm.
Scott
Ken, Thanks for the suggestion. They're installed, the splash of color is growing on me and I've decided that I need to find more parts that I don't change so I'm going to keep them as is
Rus, I'm glad you're enjoying the writeups. They help me remember what I've done and hopefully provide some value to community that has taught me so much. BTW, some things get redone multiple times and I can't go back and edit old posts. For example, I'm currently working on new uprights. I had what came with the kit, I upgraded when RCR offered their new version (which I machined) and I'm now planning on CNC'ing different ones. Hopefully the third time is the charm!
Scott
I loved my headers in raw stainless steel so before they were coated I had them photographed. The photos just arrived. He did a several 360-degree shots using a rotary table. I'm going to convert them to video, but here are few. Note that the joints that aren't as pretty are where the tube steps from 1-7/8" to 2" so there is bulge on the OD.
Scott
Just like fine jewelry
My wife doesn't think so!
I think there is a rule against PORNOGRAPHY on this site
I'm working on a plugin for my website so that you can interactively spin them 360 degrees.
Love to hear how those sound.
Me too! It will happen in 2024.
Over four and a half years ago I modified the fuel filler neck to clear the throttle body and the induction tube. The mod isn’t difficult, but you need someone with good welding skills because the neck is made from thin spun aluminum.
tock (left) and modified (right)
The modification avoids the throttle body, but it guides things into a tight space between the 2”x 2” chassis rail and the oil reservoir. I used a flexible tube to connect the filler neck to the fuel tank. That worked, but it looked like ass and it rubbed both the chassis and the top of oil reservoir.
I recently pulled the engine and wanted to see if I could come up with a better solution. I started playing around with some 2” OD aluminum mandrel bends to determine if hard tube would work. After making a couple of cuts for mocking purposes it occurred to me that I had a whole set of 2” icengineworks blocks that I had used to design the headers. DUH! Fortunately I figured this out before wasting any material.
While designing the headers I found it difficult to conceptualize the shape when adding one block at a time. However, I found it intuitive to pre-construct J-bends and U-bends, hold them in place and then snap them apart in the desired location and, if needed, add or remove additional blocks. I was able to get a perfect fit with three mandrel bends clocked at different angles.
Perfect match to the prototype. Everything welded and hose beads rolled into each end.
At first I was concerned that the angle of the fill neck might make refueling difficult. However, with the stock setup the nozzle is typically pointed directly into a 90-degree bend whereas with the modified angle the nozzle is pointed straight down with no impediments.
It’s really tight, but even with body deflection nothing is going to rub. The horizontal hardlines are for the heater and the coolant bypass. I still need to add a cover plate to seal the firewall around the tube. The two bolt heads visible in that opening are for the rollover flapper valve.
I like where the fuel tank is located. However, it’s clear in this picture that fuel filler neck and fuel door are mounted to the fiberglass body and if the car rolled the fuel door could be easily torn off resulting in a 2” opening pouring vapor and gas into the engine compartment in close proximity to the headers. People worry about putting a rollover valve on the 6AN vent line, but ignore the fill tube which is 28 times larger. I replaced the stock fuel tank with a FIA-compliant fuel cell which, amongst other safety features, has a rollover flapper valve. It would be straightforward to retrofit the stock fuel tank with one.
The heat shields that protect the chassis from the headers are finished. They were complex because the stock 2”x 2” chassis rails aren’t parallel nor co-planar and, complicating matters, I scalloped four of the chassis tubes to accommodate the headers. In addition, there were several hoses in the way. Fortunately, the guys at Back Bay Customs are excellent fabricators. The left side is a single piece and the right side is two pieces to accommodate the dry sump filter and lines. Everything is removeable with the engine and headers in place.
The chassis tubes were scalloped in previous post to accommodate the headers.
Paper and tape were used to make templates
The heat shield conforms to the scalloped 2” x 2” chassis tube. 1/8” shims were welded to the back side of the heat shield to provide an air gap between it and the chassis tubes. There is a small heat shield mounted to the engine block to protect the back of the alternator.
Nice work. Heat shields are frequently overlooked or unappreciated. Radiant heat can damage fiberglass bodywork. Here is how Manta Cars did theirs back in 1976:
Scott
The holy grail for many SL-C builders is a comfortable car on the street which can also tear up the track. While it’s impossible to optimize for both, technology can help transition between the two use cases. To that end, I’ve added cockpit-adjustable anti sway bars, driver tunable electric power-assisted steering, an active wing, and multiple engine, traction control and shift tunes. These are collectively modified via the manettino rotary switch on the steering wheel. Once a given mode is selected, the driver can dynamically tweak any of the settings.
Over the last couple of years I’ve been trying to upgrade my Penske dampers with TracTive’s semi-active dampers which are apparently used by Pagani, Donkervoort and a variety of track/race cars. Similar to the banned F1 active suspension technology the damping rates are dynamically modified by an ECU based on settings and multiple accelerometers. For example, going through the same corner with the same speed, once on the brakes and once on power, you would see totally different damper settings for all individual wheels. However, unlike the F1 tech the ride height is not changed, hence the semi-active moniker.
The TracTive ACE dampers can transition to any desired stiffness setting in 6 milliseconds. According to the manual:
To dampen the wheel and body movements, the motion of the vehicle is monitored. The following axis are included:
  • Vehicle Vertical Axis (Z-Axis)
  • Vehicle Lateral Axis (X-Axis)
  • Vehicle Longitudinal Axis (Y-Axis)
The following signals are used for monitoring:
  • LATERAL acceleration
  • LONGITUDAL acceleration
The following signals are used to calculate the current driving situation:
Control of the damping action for the vertical movement of the vehicle can be subdivided into comfort and safety. The ACE system is set to use a small amount low-speed (body) damping to enhance comfort. At the same time, the wheels may not loose contact with the road-surface. Depending on the situation, the TCU control algorithm should shift towards optimized vertical force transmission.
Lateral G-force
The ACE system is able to detect steering input by monitoring lateral G-force. (e.g. transition from driving in a straight line and into a corner) When a rapid enlargement of the lateral G-force is detected, the TCU concludes that cornering has begun. As a result, the dampers can be adjusted accordingly. This means that the ACE system can be used to reduce the rolling motion of the vehicle. This “anti-roll” behavior is programmed inside the TCU and is specific to each application.
Longitudinal G-force
Using the longitudinal G-force, the ACE system is able to determine whether the vehicle is accelerating, braking or moving at constant velocity. During (excessive) braking, the vehicle would normally see a pitching motion. While the acting G-forces are detected by the TCU, this pitching motion can be counteracted by increasing front damper stiffness. Based on the G-force-rate and/or the absolute G-force, it is determined how much increase or decrease in damping is required for optimum wheel and body control. The same goes for sudden accelerations, depending on the application, either a stiffer or softer damper is required to gain maximum grip on the driven wheels. This is done by using the longitudinal G-force together with the control algorithm in the TCU.
Combined G-forces
Combining both longitudinal and lateral G-force, actual driving situations can be extracted from the sensor data. Different damper behavior can be set for all kinds of combinations. Going through the same corner with the same speed, once on the brakes and once on power, you would see totally different damper settings for all individual wheels. This is how the ACE system increases safety, more grip, more control and better predictability.
The control panel shown above enables the driver to dynamically control the following four settings:
  • FRONT damping adjustments gives you control over the damper stiffness over the whole axle and not the individual dampers.
  • REAR damping adjustments gives you control over the damper stiffness over the whole axle and not the individual dampers.
  • ROLL support allows you to adjust the percentage of damping that is added when G-force is detected in the LATERAL motion to support the chassis thru the dampers while entering and moving thru the corners.
  • PITCH support allows you to adjust the percentage of damping that is added when G-force is detected in LONGITUDAL motion. This can be braking and or accelerating of the vehicle.
These settings can be be stored in five different tunes which can be activated via CAN bus messages.
The primary challenge to the upgrade is that it’s more complex than just getting the dampers to fit. The valving, spring rates and bump stops need to be engineered. I subsequently learned that Henry Nickless with Chiron World Motorsports is building two high-spec Lambo V10 SL-Cs with TracTive dampers. He has extensive experience building and racing LMP cars and setting up suspensions on a wide-range of cars, so I’ve been working with him.
Starting with first principles, the chassis and suspension were scanned and a 17-page vehicle dynamics report. The good news was that the front suspension geometry was spot on and there was no need for any changes (the rear didn’t fare as well, more about that in a later post). We opted for a hydraulic nose lift that’s seamlessly integrated into the top of the damper rather than the typical cups that go around the shock body. This approach has several advantages:
  • The springs are standard length which provides increased suspension travel, especially after a bump stop and bump springs are added.
  • It’s more compact which results in less weight.
  • The hydraulic ram is located at the top of the damper, so it’s weight is sprung. The cups have a larger OD which often collides with the upper control arm, resulting in the shock being inverted and the weight becoming un-sprung.
The downside is higher cost and that the shocks are longer.
Penske front damper with with RamLiftPro cup (left), TracTive front damper with integral lift (middle), TracTive rear damper (right). The two silver plugs at the top of the middle damper are M10 1.0 mm hydraulic ports for the nose lift.
Initial observations:
  • The TracTive dampers appear to have the build quality as the Penske dampers.
  • Other than the thin wire exiting the bottom of the TracTive dampers, one wouldn’t know that they were active.
  • The springs on the TracTive have a smaller OD whereas the Penske’s.
  • The TracTive reservoir hoses have a larger OD.
  • The TracTive lift has two hydraulic lines per damper whereas the RamLiftPro has one.
To accommodate the longer damper a new top bracket was CNC’d from 7075 aluminum. It uses the lower stock hole and requires two new upper holes to be drilled. There is small bump on an the backside of the damper to accommodate the hydraulic piston and a small hole must be cut into the monocoque. I laser cut a plywood jig to cut the hole with a router. That was easy. However, I had nut plates integrated into the removable side-impact bars which required a fair amount of rework.
Top front shock brackets, flanged bushings and indexing cone washers (all shown parts are custom)
Installing/removing the stock dampers is a pain-in-the-ass. You need remove one side and loosen the other side of the upper control arm and then you have four stacks of flat and cone washers for the that need to be aligned and held in place while you push the bolt through the assembly. Inevitably you wind up dropping one or more stacks on the floor… I’m constantly amazed how far stuff can roll to a find creative hiding place.
With this version there is no need to touch the upper control arm. Each stack for the top rod end is replaced with a single flanged bushing that indexes the bracket and each stack on the bottom is replaced with a single cone washer that indexes the rod end. Since everything is custom machined it slides together like butter and the parts hold them in place while being installed.
In the pictures below, the shock has been installed. You will note that it projects above the monocoque which requires the notch in the spyder’s fiberglass on to be extended. However, there is no effect on the nose. Also note that the hydraulic lines haven’t been installed yet and that reservoir hose is routed under the control arm, but the plan is to route it above the control arm.
The hydraulic nose lift system is contained in a compact stainless steel box considering that it includes the hydraulic pump, reservoir, valves, and a motor controller. The RamLiftPro system includes a rocker switch to reverse motor direction which runs power to the cockpit. The TracTive system takes decentralized approach wiring approach. Power and ground are wired directly to the unit and a control wire with a supplied button controls everything. This reduces weight and keeps power out of the cockpit.
There isn’t any information on the website or documentation for the lift kit. To my understanding it’s currently used by a couple of OEMs (I think Pagani and Donkervoort) and I only learned about when asking them for specs to design/machine a similar system. I’ll post more information one I get it plumbed up and tested.
The hydraulic system
Lateral G-force
Combined G-forces
There is much to be said for simplicity. Complexity begets unreliability and if a critical system fails, will it be dangerous?
Come on Neil the whole car is dangerous. This is about boys and their toys. I personally love the range of innovation that individual builders incorporate into their personal builds. My car is very basic and its a blast to drive. That being said If I could afford the time and money to do a top level car I certainly would do it ( Or if I hit the lottery will do it ;))
