Took a drive this AM and discovered a massive amount of exhaust gases entering the cockpit through the seam between firewall and the frame.
What are the best ways to keep the gases out yet ensure the firewall is easily removealbe (ie, no sealants)? Same for the tunnel where the ZF calbles and the coolant pipes run.
Am in process of covering engine with lexan and sealing off carbs. That's going to make a lot more gases available to leak into the cockpit so want ot fix problem now.
With Webers, what is best way to rounte valve cover gases (most of the gases leaking into cockpit) back into motor versus just filtering and venting?
Thanx
Mark
Thanx
Mark
