what size is the clutch master cylinder in early CAV cars. My slave is crapping out and I want to match a new one with the master to ease up the pedal pressure. chuck
Hi Chuck,
Also it's worth checking to make sure the bellhousing was "dialed in" using offset dowel pins during initial assembly. This is standard practice when using a non OEM bellhousing although it's a step easily missed.
You might be able to see the slotted or hex keyed heads of the offset dowel pins through the bellhousing casting where it meets the block.
