Anti-sway, roll bar manufacturers?
I'm considering some roll bars for two car projects that I have in house. One of the projects will be extremely weight sensitive and I'm interested to know if any of you have experience and/or sources with hollow roll bars?
All the bars I've used in the past have been solid and with examples of large bars like the one on my Z are damn heavy.
Re: Roll bar manufacturers?
HI Ron Are you talking Anti Sway Bars ??? If so check these Tubular and Solid Sway Bars We use these on the Super Late Model for Chassis tuning. Any of the supplers of Stock car susspention parts should be able to help get you close to what you need.
Julian
My only experience of hollow sway bars is on a Pantera and there are numerous accounts of them failing. Now whether that is the particular brand and steel type, wall thickness etc. that supplier is using is another question..... I suspect it is.
Ron, the rear bar on my GTD is 5/8 od .120 wall thickness 4130. If you think you need more bar then go with 3/4 od. It's about 3 bucks a foot so you ought to be able to make one for $25-30. Mine is simple, straight in the middle with each end bent at 90 degrees. About 3 foot center section and about a foot long for each torsion arm. Weld on a piece of 1/8 X 1 flat stock on each torsion arms with about 8 holes in it a inch apart and you have a simple adjustable bar. Use off the shelf roll bar bushes and clamps. Make up some links with some cheap 3/8 rh lh rod ends and you're good to go.
Mine has been on the car for years without any sign of taking a set, cracking, or anything else. The guy who bent your roll cage should be able to bend it for you. Piece of cake
Thanks for the links fellows. Good picture there Howard, that is exactly the sort of thing I'm looking for. Hotchkis also had a nice site explaining hollow roll bars and the weight savings with them etc. It looks to be a fairly easy thing to fab up as needed.
hi Ron,
Im building a GT40 from scratch. Im useing a similar set_up to Howard, but im useing 1" x 16 swg( 1.6mm) 4130 tubing, which I imagine would have a similar strength, to Howards sway bar, but be lighter....Im still building my car, so as yet it is untried
To make it adjustable, I have used a sliding clamp arrangement, which would be quite a bit lighter than useing a plate with holes.....I dont know how to post pics on here, so if you send me an email [email protected] I will you send you some pics showing the clamp system
mick
Terry Oxandale
Skinny Man
There was no mention on this string of heat treating any of these bars after they were bent. Am I to understand you're using DOM or mild steel tube with no treating process?
Thanks,
Terry
Hi Terry
I used chrome molly 4130 tubing for my sway bar
CM comes in 4 grades As Drawn...Annealed....Normalizid....and Quenched, and Tempered
I bent my sway bar from Normalised. It would only be nessecarry to heat treat it, If i required it to be stiffer
Heat treat only affects strength of the steel, not the stiffness of the bar. You need to heat treat if the bar yields in use. If it doesn't yield, heat treat won't make a difference to roll resistance.
Terry Oxandale
Skinny Man
Makes perfect sense. It sounds from the experience put out so far that the normal suspension roll does not reach yield strength for the bars in this string. To me this also supports a stiffer spring rate in order to prevent this. But until I have hard numbers, I've no idea what the yield strength of these bars would be (un-treated)
Malcolm
I am makng some ARBs soon for my current project and plan to use hollow tubes like you Ron. Somewhere on this computer is a simple program to calculate the "stiffness" of a bar so you can work out what you have been using and what you need to replace it with to get the same or stiffer bar. I will post it when I find it!
Hi Tom.
Thanks for the info. I had read Fred Puhns book, but I had never fully understood what he meant, but now thanks to you I do...
Tom, could you please explain to me in simple terms, what the Yield, and Tensile strenght means
Terry,
I have some info, on tensile strength and yeilds of ERW, DOM ,CFS3, and Chrome Molly, Im having trouble uploading the info on ERW, on here, if you email me, ill send you the info, my email addy is [email protected]
Here are a few sites with info about chrome molly
Performance Metals Australia- Product Information - 4130 Round Tube
http://www.suppliersonline.com/propertypages/4130.asp
And the info on DOM, and CFS3
I hope this is what you are looking for
Kevin here is a pic of a simple sliding clamp I used on my front and rear anti roll bars
mick
Kevin,
if you scroll down to the bottom of this page, there are 5 threads on anti roll bars, if you look at Malcoms thread you will see a pic of Howards front anti roll bar
mick
