I had to do some work on the G97/50 gear box. I asked a few questions on another thread about flipping it over and converting it to a 2wd from a AWD. Before you go any further, understand that I have never looked inside the magical case of gears called the transaxle.
I called Stanley at GBox and he was great! He talked me through the process. As you might remember from the first few pictures, this box was right out of the Porsche.
The rear out put needs to be cut off and the hole plugged. When I heard that I laughed and almost crapped my pants but it really wasn't that hard. I took the rear yoke off and cut the shaft just a little bit lower than the lip of the case. Then all I would need to do is put a cap or freeze plug over the end and done, right?
NO.
You see, when you take out the yoke, the case is no longer sealed. To be sure that all the metal dust from the cutoff wheel is gone I was faced with the ugly truth that the case had to come apart.
You can see a little bit of the shaft where I cut it. I figured that since it was apart I would cut the remaining excess shaft. You can see in this picture that the shaft is totally cut off.
To make the cap I had to get creative. It was a 2.5 inch ID hole. I took a 2.5 inch hole saw bit and cut the teeth off leaving about 3/4 inch of bit left. I thin cut the threads out of the top of the hole saw bit with my plasma cutter. Next, I welded a 3 inch washer to the top of it. I sat down in the tranny a little and formed a good fit. I should have taken a picture of that but you get the idea. I used the "right stuff" the seal it in the back of the box. I used that sealer to seal up the case as well.
A little decoration finished the project.
