This is very low tech, but I keep a piece of styrofoam in the drivers door pocket, if I'm pointed up hill or on an angle where the door wants to close, I just stick it in the front part of the door jam, works just fine. You want it to be soft enough that If you forget to remove it, pulling the door shut will just compress it a little and not crack the fiberglass.
