I am rewiring my GTD. It has a MSD system in it. It starts and run fine but continues to run when I turn the key OFF. I have to pull the coil wire off the switch to stop it. Any ideas?
One thing that is a trick for new players is that the cooling fans ,when running, are motors but become generators when driven by the air passing through them.
There is an inbuilt design flaw in the factory supplied GTD wiring loom. This may not apply to your situation as you did not provide the info necessary to determine it but it goes as follows;
It you are running your car on a hot day, and to keep the engine temps cool, you manually switch the fan override on, should the water temp rise enough even then so that the automatic cooling fan switch temperature is exceeded ie would have turned the fans on anyway if you had not manually put them on, you will not be able to turn your engine off! No idea why it does this but it does do it! Bizarre. Fortuanetly it is quite a rare occurrance and also you just switch off the fan override and the engine dies as it should.
Hi all
Also if they are running when you turn off the motor they will generate power which will back feed and keep your ignition live.
They also require diodes.
Dimi
First I have to say thanx to all the great advice to the new guy.
The MSD web site addressed the "run on" problem. They say put a 1amp/100volt diode in the key-coil line. That is a dinky little piece of electronics. But I'll try it.
I had put a simple on/off toggle in the line at the ignition switch that kills the coil. It works. It could be hidden as an anti theft switch.
I will have to work on the fan overide. The wiring harness I have does not have that provision.
Thanx again,
Sam
Sam,
best to go to www.msdignition.com, go to trouble shooting and it's all there under "engine run on "
