Have made a bit of progress in the last week, Chris {Flatchat] was kind enough to get all my parts back to me in good time, thanks mate, so i was able to then assemble up the rear uprites and then modify the brake caliper brackets to take a Wilwood 4 pot caliper
once i had that under taken i then could dummy things up and get drive shaft length etc, so what i wound up with was a half shaft length of 15-1\2" so with the 14x15" wheels it will give me an over all width at the rear of 1850mm, 50mm wider than i was hopeing for, but its close enough that it will still go on a trailer, just.
I then got busy and mounted the plate that will hold the 2 gall dry sump tank, which i will lighten some what once the mounts arrive so i no where i can remove alloy, i then mounted the engine oil cooler and the catch can come breather
The other little headache i had was the coil packs, they wouldnt go back on top of the rocker covers because of 1/ the injection trumpets were in the way and 2/ the exhaust was in the way as well, so what to do bar drilling a hole and fitting a dizzy, i came up with a solution while enjoying a coffee break this morning, hang them off the side of the chassis under the exhaust, all i had to do was remove them individualy from the mount plate and reverse them, then bolt them back on so the wiring is still stock and the coils are back in OEM position and i can still use stock leads..
hopefully the sparky will appreciate my effort when he comes to wire it all up.
so its comming together slowly
cheers John
