Hi Peter,
If my memory serves me, the chemical make up of fire wires is Sodium Dioxide (SiO2) which goes open circuit at either 495c for an overheat or 695c for a fire. The open circuit idea is to maintain continuity for integrity testing. Wires are arranged in pairs ie two overheat and two fire so that you have a primary and secondary and both have to detect to configure the warnings which are in the case of overheat a screen warning plus attention getter and in the case of a fire, screen warning, loud shrill bell, and electro-mechanical unlocking of the fire extinguisher handle which is also illuminated. To just follow on what happens when you operate the handle you have two shots which you use 30 seconds apart (if the first shot does not extinguish the fire) and it's pulled out and rotated one way for the first shot and the other way for the second. It does just about everything to stop the engine - fuel off, generator off,bleed air off, hydraulics, oil, pylon fuel valve, you name it it does it. And then about 30kg of Halon goes in per shot.
In the event of undercarriage overheat - the 747 bays are so vast and so well ventilated anyway that anything but lowering the undercarriage again is a waste of effort.(So if you've just taken off as a Pax and suddenly the undercarriage comes down again - usually about 30 seconds after it's just come up on take off - really fasten your seat belt and adopt the position) This is all from memory by the way as I haven't flown the 747 for 6 years and I had a stroke in 2002 so there are some holes in the memory bank.
Now, looking at our cars and the scenario you pose - firstly yes it could be done, secondly at what cost, and thirdly - what changes in how we could configure it could be suggested.
Maybe you could arm a system to operate independantly and automatically, maybe with a parallel operation through an inertia switch. So many other possibilities. There may be other sensors on the market that would do the business instead of fire wire. I wish we had this thread at the end of last year's season as I could have devoted a bit more time and had a look around through the winter (sorry Peter - your summer). Maybe next winter as a project. Anybody else with anything to add or other useful products they know of - answers on a postcard ?
Dave M
