Got my GMPP harness today; engine will be here on Tuesday.
I hate EFI - this thing looks complicated
Why Fran no make car fit MASSIVE carb intake like an ultima
That should tell you something...
That is correct
2- you can buy a U shaped heater hose that has 5/8" on one end and 3/4' on the opposite end. The part number is DAYCO #87629
Alex, You don't need to hook up the fuel pump or the fan wire. It will run just fine. I use the fuel pump wire for the low presure and the fan wire for the oil cooler fan but I don't have the ISIS stuff.
The tach will work fine if you use the step up resistor. It sounds much more complicated than it really is.
Now isn't the time to be cheap Alex.:shocked:Next question
When installing the transaxle adapter to the engine, as well as the engine mounts to the engine, is it okay to use grade 8.8 bolts? I'm sure it's fine for the former, but the later (engine mounts to engine) I'm uncertain of.
Or will it go 'OMFG! NO OIL PRESSURE! I NO RUN!'?
