Based on my experience, the cast iron fittings will corode quickly. Change them to brass or stainless.
What is a Accupump?
Actually wet sump. It is a preset pressure device that if the oil pressure goes below the limit set, will pump 3 quarts of oil into the engine. Usually in an oiling system that is not baffled and has washup onto the walls in high speed turns, or the pickup comes out of contact with the oil, etc. When oil pressure returns, the oil is pumped back into the unit and is held til needed again. Some use it with start up to pre oil the engine prior to startup. Just depends on how you set it up the system.
Thank you for that information, and I take it you have to run a dry sump with the LS motors?
