SouthernGT No6
Loose lock nut at bottom of last photo as well if that helps
Iva test looks tough. Presume you have all the holes blanked for noise test?
Thanks Ryan, lock nut left loose for adjustments.
All holes blanked as you cannot have any sharp edges in case when you are reversing over a pedestrian they cut their hands on them, or a part of the IVA sphere representing a body part comes into contact with a non correctly radius part when pushed through any aperture.
Trying to comply with IVA rules
1 Fuel caps tethered
2 Switches and warning lights labeled.
3 Steering wheel holes covered and padded thanks to Andy Green.
4 CAT 2 immobiliser fitted.
New chief mechanic tried to find the reason for my misfire no luck yet
https://www.youtube.com/watch?v=KVfzEMNipcc
Your new assistant has a budding career as a car relicer. I have rarely seen such intuitive artificial patina skills... :thumbsup:
Took some time off to build our granddaughters first car for her first birthday today. Actually managed to get this build right, not sure it will pass IVA though.
Hi Nick,
Must be nice to build something that comes with a clear set of instructions, instead of working it out as you go along :laugh:
Rgds,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
Andy<o:p></o:p>
Hi Nick,
Andy<o:p></o:p>
:lol:
That's what I thought Andy until the steering column had to be forced into it's aperture, and some of the panel gaps were not uniform.
Think I may have been reading to many build threads. :laugh:
Quick visit to SGT to pick up my heated windscreen,borrow some bits for IVA and have a snoop around.
Pictures show car in for gearbox change, MK2 race car being made road legal and ready for IVA, customer complete full build in progress, and starting a new chassis.
Is that the '2nd generation' ZFQ Nick?
For IVA back lights now have to be vertical, so this requires a precision piece behind the lights to make it so. Unfortunately the precision piece was not precise enough requires a bit more to comply.
Yesterday was a good day with the heated windscreen and bulkhead glass after a bit of trimming fitted for me.
https://youtu.be/aZYQKLR20pM
Unfortunately, came crashing back down to earth today with one of those days when I thought the best way forward would be to put the whole lot on eBay at a bargain price :(
Firstly the heated screen does not seem to be heating although indicating 11 amps on my meter is being draw when switch on.
Then the screen water jet nozzle was to low and although water was getting on the screen by deflection I suspected IVA would require a direct jet onto the screen. Unfortunately, there is a wiper motor wheel box directly below the nozzle so very limited access. I thought I had loosened the nozzle nut off enough to ease the assembly up a bit, I was wrong disaster.
So now it was a case of removing both fuel tanks to gain access to the dash bolts then removing everything required to ease the dash out, or butchering the bodywork to gain access to fit a new nozzle.
Being me I depressingly went the butcher route.
Hi Nick,
In the grand scene of the build, this will seem a minor irritation!
Tidy the hole up and fit a rubber blanking plug and if anyone asks it was a period race modification :laugh:
Rgds,
Andy
That is the nice thing about fiberglass - it is easy to fill up mistakes and sand it back to look like nothing ever went wrong!!
Hi Nick,
Rgds,
Andy
Thanks Guys,
Was thinking of both of these methods, don't suppose you know where I can get an oblong rubber blanking plug Andy?
