SPF #2285 Born, But Still Coming To Life
Robert S.
Re: Braces For Our p2285 . . .
Robert where did you get that canard setup? I want them, looks great.
Nick,
I did purchase my conards at Olthoff Racing. I can't remember if the brace bar for the conards were supplied by Denis Olthoff, or if I purchased them separately.
Those conards were priced fairly, and tended to match my brushed side mirrors. Their curvature provided flexible positioning forward and back, as well as the downward angle.
HTH, Robert p2285
Robert S.
GT40 Mrk I p2285 — Conard and Conard Brace Install . . .
HTML:
Robert S.
GT40 Mrk I p2285 — Picts Of Lift System Install GT40 . . .
HTML:
The lift system can be configured to lift only the front body, or it can lift both the front and rear body. I opted for the four wheel lift system.
Robert S.
GT40 Mrk I p2285 — Hydraulic Lift System Company . . .
HTML:
Car lift system makers are sometimes difficult to locate because: there are hydraulic car lifts such as the low rider lifts; those lifts fill your car trunk with much equipment. They can lay the car flat on the ground (slamming it), and/or raise it very high.
The type of lift I was seeking would raise and lower the car nearly 2”, and would take up hardly any room.
I had the best luck when I searched for auto suspension lifts. The brand name of mine was KW, and they are sold at most larger auto parts stores, and internet stores. Earlier on this build thread, I did show picts and video of the small control box. I elected to install it in the front nose area. I also showed photos of the lift mechanisms beneath the coil-overs. Maybe search by key name lift. If you can't find it, I'll try to search for the picts. BTW, I did forget to mention they also have a remote control FOB.
Robert Sackett, GT40 p2285
Here is a two minute demo video: https://www.youtube.com/watch?time_continue=68&v=Y0H-bfUKRxI
Robert S.
GT40 Mrl I p2285 — Intakes, Stacks and Air Filter Resistance
HTML:
<style> <!-- /* Font Definitions */ @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-fareast-font-family:Cambria; mso-hansi-font-family:Cambria; mso-bidi-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style>​
For those New GT40 Builds
View attachment Intakes, Stacks and Air Filter Resistance.pdf
Robert S.
Ian,
You have a sharp mind my friend. Yea, I think we (my mechanic and I) figured it out. I found some very small but sharp metal fragments on a couple of the pulleys; No doubt from other fan belts that burned through their rubber ribs and burned the steal inside of them. Once I burnished those off, I then decided to really add more tension to the belt once it was put on, then it worked as it should. It likely sounds strange but my mechanic didn't detect the steel burrs and only guessed at the amount of tension. Thank you for remembering and for caring about my small problem that caused much towing and other expenses. Robert
Look at Raceline Digital, Do More for Less for the numbers. Remember the Gulf cars raced other places than LeMans with numbers other than "6" and "9"!
You can do the black outlines in permanent vinyl and use the removeable numbers to allow you to "change-up" once in while. Hey, keep 'em guessing by showing up with different numbers at different shows!
Every Gulf car shows up as a 1969 LeMans unit with "6" so have some fun with the other events.
Thanks Rick for the Raceline advice. I will be purchasing a graphics kit when my SPF 40 in the original Gulf livery (Indigo Blue/Orange) arrives soon.
Hi Rick, Dave Glancy here. Can you provide price and details of what is included in your insulating kit to keep hot air out of the cabin for a SPF GT40 MK I (P2505)? Thank you, Dave
Rick Muck- Mark IV
GT40s Sponsor
Much covered in this thread: https://www.gt40s.com/threads/spf-gt-water-air-sealing-the-diy-thread.29631/
The "HVAC" seal kit consists of 4 custom molded seals and adhesive with instructions. it is $108.60. The "vent seal kit" has two molded silicone seals with pressure sensitive adhesive and instructions. This kit is $68.50.
The "closed cell" foam we have used is scavenged from packing materials, commonly found is computer/electronics packaging. The foam is waterproof and has a slightly 'rubbery' feel. It cuts easily with a hacksaw blade or knife.
Kits may be ordered at [email protected] or 716.812.3938
To Jimbo, Jim Craik, Alan, other friends and interested souls,
Six months ago the components that would become SPF #2285 began the fabrication and assembly process. *See bottom of this post for more build details.
On 28 May it was placed on board for its journey to N.Y. Harbor. It arrived on 23 June, cleared customs on 26 June, and was placed on a rail car on 28 June. It arrived, and is on the ground in Los Angeles, and will be trucked to Superformance in Irvine, arriving most likely on Monday or Tuesday, 16 or 17 July.
I did decide to go with the RBT or ZF transaxle. I still wanted a sequential, but most are made overseas, and those made here are mostly for off-road vehicles, and basically, no one knows too much about the paddle wheel computer controlled shifting mechanisms. No one that is except the companies who cater to the million dollar racers who have $45k budgets for the sequential tranny, and another $35k for all the shifting mechanisms.
There are both decent sequential trannys and shift systems made for far less than the NASCAR ones, but no one mechanic (nearby) either knows how to join the system, or has ever installed one. I really don't understand these circumstances too much, but I just had to move on. And yes thank you, I know the demand for such is not high. However, there were many who expressed interest in such systems, along with me, but they too were wary.
I went with Roush Performance Engines, and they agreed in principle to build a custom engine that is expected to be north of their top of the line 576 H.P. GT40 crate engine. It will feature a solid roller with additional valve train girdling for added strength at 7k rpm. I had to accept the idea that it would take longer, cost more, and have a 90-day warranty instead of 2-years.
The extra build time will consist mostly of intake polishing and bench flow testing of the exotic, relatively new FI intake, which has its own pros and cons, and may cause traditionalist unintended pain and suffering. They also agreed to use a different ECU of my choice, which also really pleased me.
Since this ride has the wider of the two wide body clips, it required the custom build of the two rear 15" spinner wheels. At the moment, I can't remember if they will be 13.5" wide, or 15" wide, but should learn that soon, as I hope to be there in person when they remove my ride and three others from the 40' steel container. The cars are shipped without wheels and tires, but I’m certain the wheels are already at Superformance, who organized their making. I hope to take video and picts, provided Superformance gives me advance notice, which they have promised they would.
I suspect its months away from becoming registered and driveable, so I'll continue to grin and bear it.
*Following from 12 May:
You are correct Jim. Just yesterday I was notified it is tentatively scheduled to be shipped in two weeks, but one never knows. In addition, it will supposedly take six weeks to arrive at either the Long Beach or San Pedro harbor, left coast. They sent me a few picts as the body clips were just coming out of paint and being moved to final assembly, and that was three weeks ago, or so.
I guess the personality of this roller would consist of these elements: (going back six months from my significantly compromised memory remnants due primarily from the journey through the sixties): It's a MKI, Gulf livery (Special paint on Gulf orange is Lambo orange pearl [One can hardly discern the difference of color under diffused ambient lighting, but in direct sunlight the pearl alters the highlights from the normal Gulf orange to yellows and golds], it's the more extreme of the three body widths available and will require wider 15" wheels and tires, Gurney bubbles each side, leather upgrade, illuminated roundels, there is another upgrade to the interior with the door jam molding, carpeting, or some such components? Well, there may be other smaller items, but I can't grasp it just now.
Robert
Robert, I think your sometimes subtle change to Lambo Orange (sometimes less subtle) is inspired and I can't wait to see this modified livery! Our P2505 MK I just hit US shores and will also sport Gulf livery. Our GT will be the Indigo Blue/Orange livery and knowing how excited I am, I recognize Robert surely feels the same way. Further, I am looking forward to admiring the wide body, those transom angles will be wicked!! Congrats! Dave
Brian Kissel
Dave, Robert hasn't signed onto the forum in almost 6 years. That's not saying he hasn't lurked but we haven't seen him in years.
Regards Brian
Regards Brian
Well... That's kind of embarrassing I didn't know that. Thanks for throwing me a life line Brian! I saw the year on his post but figured he was just... OK, I will stop digging that hole now...
It's all good Dave. There is a lot of good information in this thread,
Regards Brian
Thanks for that. And I know about all the great folks and the information here. FYI, our 40 just hit US soil (Port of NY) and is on it's way to the dealership in IN. I will be sending updates as they come. Dave
