Here some datas from the net.
Overall, a vehicle weight reduction of 1% is claimed to give a reduction in fuel consumption of some 0.7%. Weight reduction in the moving parts of the engine are however likely to be much more effective in achieving improved fuel economy than body weight reduction. Titanium alloy density is some 60% that of steel, and the elastic modulus is about half that of steel. Direct substitution of steel parts with titanium is rarely the best way to proceed, but in practice should produce an immediate weight reduction of at least 40%. The low modulus of titanium is beneficial for springs, but component redesign may be necessary in stiffness limited applications. Specific strength, and likewise specific toughness and fatigue limits of titanium compare very favourably to both steel and aluminium alloys.
<DIV align=center>
Table 2. Comparison of specific strength of engineering alloys<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
<TBODY><TR style="HEIGHT: 45.25pt"><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: black; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none; HEIGHT: 45.25pt" vAlign=top width="20%">
Material<o></o>
</TD><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: black; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none; HEIGHT: 45.25pt" vAlign=top width="20%">
Density kg/l<o></o>
Youngs Modulus (GPa)<o></o>
Yield Strength (MPa)<o></o>
</TD><TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: black; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none; HEIGHT: 45.25pt" vAlign=top width="20%">
Specific Strength<o></o>
</TD></TR><TR><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none" width="20%">CP Titanium<o
></o
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; WIDTH: 20%; PADDING-TOP: 0cm" width="20%">
4.51<o
></o
105<o
></o
250 – 450<o
></o
</TD><TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none" width="20%">
50 - 100<o
></o
</TD></TR><TR><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; BACKGROUND: #e0e0e0; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none" width="20%">Ti-6Al-4V<o
></o
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; BACKGROUND: #e0e0e0; PADDING-BOTTOM: 0cm; WIDTH: 20%; PADDING-TOP: 0cm" width="20%">
4.43<o
></o
112<o
></o
900 – 1100<o
></o
</TD><TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; BACKGROUND: #e0e0e0; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none" width="20%">
200 - 250<o
></o
</TD></TR><TR><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none" width="20%">Ti - LCB? <o
></o
4.79<o
></o
110<o
></o
950 – 1400<o
></o
200 - 290<o
></o
</TD></TR><TR><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; BACKGROUND: #e0e0e0; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: medium none" width="20%">Carbon Steel<o
></o
7.8<o
></o
200<o
></o
350 – 450<o
></o
45 - 60<o
></o
</TD></TR><TR><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid" width="20%">Aluminium Alloy<o
></o
</TD><TD style="BORDER-RIGHT: medium none; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid" width="20%">
2.8<o
></o
70<o
></o
100 – 350<o
></o
</TD><TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: medium none; WIDTH: 20%; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid" width="20%">
35 - 125
</TD></TR></TBODY></TABLE>
