Shaun
Evening all
Ok so filled my recon UN1 last night to just below the fill hole as I ran out of oil, that was 3L, popped up tonight to see a puddle of oil under the box, seems to be coming out from the drive shafts, worse on the passenger side, I assume UN1 is fill to plug level? If so then any thoughts as to why this leaks, it was sourced from Chris Cole via SGT as a full rebuild with LSD
I will be none to happy if I have to pull the box as need an engine start soon to boost moral
