What is the largest engine that can fit in the SL-C?
So this ad says "LS7"...and all forged already. Would this fit in the car?
Likely a chevy 427ci, just trying to find a pathway to get one built or build myself that has all forged internals already, incase I ever want to put a blower on, or put it in a different vehicle.
A large displacement SBC will save you considerable weight over a BBC. My black Mirge has a 383 ci Donovan aluminum block (SBC copy) and I find that it is is quite satisfactory. This engine weighs 400 lbs complete.
So this ad says "LS7"...and all forged already. Would this fit in the car? View attachment 133726
yes, that will definitely fit - it has small block dimensions basically (though mounts are different). But given the build, I'm guessing that they optimized for NA, with high compression and tight ring gaps. Not sure it would play well with forced injection. Though NA, depending on cam, this thing is probable good for 650HP. And it weighs about 430lbs.
