Efnfast,
+1
Great minds think alike :drunk:
Efnfast,
+1
anyways back to the topic.. i was thinking a real nasty motor in this car would be the bmw s85 ( m5 v10) i know they aren't a bargain but i've seen a full motor tranny setup for 18k or so
:shocked:
First of all you have to pay for the part in full, and then WAIT for between 3 and 6 months! Your money will be put in an escrow account where it will remain until you receive your transmission.
Second of all, there are no refunds on these orders as we are committing a huge amount to the initial order.
Not for me - all I see is the maintenance knightmare that can become
"Old school" V8 > * :laugh:
. . . to find out what to watch out for with these (Ms-series BMWs) we spoke to Andrew Askey of Manchester-based independent BMW specialists BMTEC (BMTEC - Manchesters leading Independent BMW and Mini servicing and repair specialists.).
"First of all the engines themselves are pretty much bulletproof in our experience' he tells us. 'We've seen a few of the throttle housings fail on the V8, and they're not a repairable part. Once they've gone, they've gone, and the replacement part itself is around £600. Other than that, on the engine side of things you only need to look out for the VANOS device (BMW's variable valve timing dingus which alters cam timing by six degrees either way). There is a small filter at the front of them which you can clean, but if you're looking at one which is rattling - especially at high rpms - you might want to walk away because a specialist will relieve you of £2000 to do a complete replacement job."
In terms of any pitfalls, that was all Andrew had to tell us after more than twenty years of working with these cars.
If we are under the impression tht the BMW V-8 engine may be a maintenance nightmare and therefore should be excluded from consideration as a powerplant for the SL-C, here is an interesting viewpoint from pistonheads.com (An 'M' For All Reasons?):
The BMW V8 is back in the hunt!
Bassanio et Portia
Looks like you guys might have another trans axle option @ a $7,800 initial order price, purchases ordered by September 14th at this price . Made for the Factory Five GTM, but possibly it would work on the SL-C? Have a look and decide for yourself.
Mods please remove this if I am out of line here posting this.
What's New
:idea: Oh-ooooh! I know what your are doing, Alex!$3500 to replace the VANOS thing-a-mah-bob ..... $3500 buys you like 1/2 a crate LS engine ... still pass on the BMW oneOriginally Posted by Bassanio et Portia View Post
Bassanio et Portia
but shrieking at 8,400 BMW V8 rpm. And you smile: Bassanio et Portia's car turned out really good.
It isn't a big rocket science to build a 8500 RPM pushrod V8 either........
