Thanks guys, Rick S, I have a Porsche 3.4 direct injection engine and 6-speed box to go in it from a crashed Cayman S, I intend to put a GT3 throttle body on and with a stand alone ecu and decent exhaust should see 340-350 out of it, so should be fun!!:drunk: Although I keep thinking I should be putting a GT3 engine in it, maybe I will make a "special" for myself once this is done!!!
Mike S, the screen I can still get from Pilkington Glass here in the UK, they have the original tooling and reckon they can get it "E" marked which is what we need here to get it road legal.
Jackal, you have plenty of talent looking at your build thread, mine looked just as yours does, I am just a bit further down the path, won`t be long untill you`re taking molds from your buck, doing a grand job!
A pic of it all packed up to go to Stoneleigh Kit Car show then home to Holland, it is hoped that this will be a demonstrator with a view to make a limited number of kits available to sell, although a lot of developement work and re-developement lies ahead before we will be ready.
In the trailer is a Caterham style car, the front and rear sections of the 917 and doors and front hatch, pretty tight to say the least!!!!!
What resin did you use with the carbon? It's my understanding it needs to be epoxy. It's also my understanding the exopy & fg resin don't stick to each other. Have you looked into the possability down the road of de-lamination of the two? Looks great just wouldn't want you to have problems after all your hard & excellent work.
Mike S.
Mike, Vinylester resins would be okay for a non structural part. I never had a lot of luck with CF open molding. Parts come out okay, but lack great cosmetics without sanding and clear coating. Polyester resins may be used, but expect a brittle part. Non-structural okay. May have the opportunity to play with some resin infusion in the near future.
Epoxy will stick to prepared polyester surfaces, but no so good the other way around.
Here in South Africa we have plenty of "speed bumps" Don't know if you have as many around as we do. On my build I'm going to use similar setup to the Murcie with a pneumatic lifter for lifting the front for such inconveniences as mentioned above. I see your nose overhang is also pretty long, are you thinking in similar lines?
Regards
Jackal
Chris:
I commend you on your perseverance on this build, knowing what it takes to get where you are now I can say that it looks like all that work is coming to fruition.
I would bet that the photos don't do your body and mold work justice, those are some nice fits and that look from the rear is about as nice as it gets without paint.
I cant wait to see what your chassis paneling and cockpit will look like.
Phil
