RCR Australia have pretty extensive facilities and quite a large workforce. We have been fortunate enough to continue to growing during difficult global financial circumstances.
As Fran indicated the Aussie RCR's are customised for local market expectations and regulations for registration compliance. Significant development has been performed here in conjunction with fantastic support from Fran. The kits to spec'd to suit the market position we are targetting here.
The RCR-40's use a very clever engine mounting system with bolt in tig welded laser cut steel mounting plates. So all the chassis are the same and only the engine mounting plates are unique to each engine/transaxle combination. This system also allows the owner to postion the drivetrain at any height and forward and back position they desire. As with our other modern engine options we would use adaptors on the block to utilise commonly available high performance urethane mounts which then bolt into out chassis mounting plates. So bolting the engines into the chassis will be relatively simple.
Fran and I have been measuring up the sizing and starting to look at the requirements for fitment. We have customers here with 4.6LT mod motors fitted, but the 5.0LT Coyote is different and will require test fitting and sorting. Especially with location of alternator, ac compressor, exhaust and air intake.
Personally I am really keen on the Coyote engines both N/A & Supercharged. They look to be a really good match for RCR products and performance goals we have for our products. A fantastic option for any Ford powered kit car. It's also nice to see a controller kit being available immediately from Ford as well to make fitment cheaper and easier.
Cam, we will sort it out as soon as possible, but keep in mind they have only just been released.
It's great to have a Ford engine you can genuinely get excited about it.
