On a left drive SPF, have any of you installed a dead pedal?
Rick, I'm liking this idea....have you ever done one as you suggest? I'd like to see a photo if you have or anyone else has done this. I think I get the picture but a real picture is worth a 1000 words they say.![]()
A 90 degree piece attached to the tub wall will work if placed right. You can rest the left side of your show on it. I would put an angled piece that mates to the tub farther forward to keep your foot from getting caught when letting off the clutch.-, i.e. a "ramp" to prevent entanglemet of your foot.
Given the stock dead pedal won't work the version of this I plan is a folded piece of sheet metal which looking at from the bottom (LHD car) would be:
(front) _|\_ (rear)
Thus the rear ramp is built into the piece; the corner between pedal surface and ramp surface can be formed "round" so there's less chance of catching a sole on the edge.
PS Rick: not with my car so I can't check this right now, but what if one pushed the footwell sheetmetal out to provide room for the stock one? Is there anything close behind it? By how much does it not fit?
....after all you wouldn't alter a GT40 tub!
Cut a hole in the tub, so you can rest your foot on the spinning tire, and it will just wear your foot down as you need. Then repair the tub, and you will have a custom foot for your GT40. Never mind all that red stuff, it cleans up pretty well.
