....but I have since installed an oil cooler with a thermostat and now I don't see much oil temp either.
Dave
I am still seeming to struggle with oil temps... has anyone put in a larger oil cooler that what was provided by SPF? I didn't run it too hard but ran it around 3200 rpm for about an hour and saw temps upward of 110C. My issue isn't 110, it is that when I run on the track I am quickly seeing 130C+ which is too high.
I am considering increasing the size but not changing the location (still over the battery on the passenger side) vs. trying to relocate it further back in the engine compartment.
Thoughts?
IIRC most of you guys above with oil temp problems @ higher RPM are running stroker cranks etc, you sure you problems are not windage related & perhaps need to look into a better sump design or perhaps a dry sump?
That's a good point, Jac.
Another thing I'm relying on completely is the amount of oil he said to put it in and his hand marked dipstick. In reality, there certainly could be too much oil in the sump and I _do_ have a windage problem.
I'm pretty sure a dry sump would cure the problem, but damn... $$$$$
