Hi all,
in search for a approbriate tool to open and close the spinners on the original style BRM´s i found this one.
Especially with the deepdished rearwheels it realy is a challenge to work with the leadhammer. I just want to be damned sure that the wingnut is as tightened as it should be.
Personally i think for most of us the only way to asure this is using a torque wrench to tighten the wingnut, because i wouldn´t have the experience to work with the leadhammer and still be hundret percent sure i achieved the torque necesarry.
These tools provide the perfect solution for this task.
They are very made for each specific application and should just be used accordingly.
Existing of high quality materials ( aerospace quality aluminum hardened and anodised) and manufactured to highest precision standards, well in this times with overflow of "eastern" tools the only expression which fits best is
"MADE IN GERMANY"
They are availabe now through us for your application.
These custom tools fit three eared spinners for the removal of Halibrand wheels or BRM wheels.
Due to the standard 1 " drive it is now possible to apply the correct torque when fitting or removing the wheel. The tools consist of a hardened aluminium alloy which makes them particularly strong while staying light and portable ( weight app 1 kg). A special plastic-inlay protects your precious wheel-nuts from being scratched or dinted.
We also have tools available for the borrani style wingnuts of the different dimensions ( please specify when order)
These custom tools fit three eared spinners for the removal of spoked wheels on Ferrari and Borrani. Due to the standard 3/4"" drive it is now possible to apply the correct torque when fitting or removing the wheel.
For those with a 3/4" ratchet we supply a adaptor from 1" to 3/4".
Also available are sockets for octagon nuts
These custom tools fit 8-point-nuts for the removal of spoked wheels. Due to the standard ¾ " drive it is now possible to apply the correct torque when fitting or removing the wheel. The tools consist of a hardened and anodized aluminium alloy which makes them particularly strong while staying light and portable.
Sizes available are from 64, 70, 75, to 85 mm and are made to fit your type. Please specify your application.
To take this nice tools with you on the road we have textile duffelbags with anti-corrosive lining for tools. This bags are available for the tool itself as also for the ratchet .
PRICES:
TOM
"MADE IN GERMANY"
PRICES:
- HELIBRAND , BRM TOOL = 249 EURO
- BORRANI TOOL = 299 EURO
- 8 Socket TOOL = 111 EURO to 249 EURO ( depends on application)
- 3/4" to 1" adaptor = 19 EURO
- Duffelbag = 17 EURO
- UK up to 5 kg = 20 EURO
- USA up to 5 kg = 35 EURO
- AUS / NZ up to 5 kg =45 EURO
- others on request
TOM
