Well, I think I have a big advantage because I am not building a street version. I also don't have much of a engine management issue. Set float levels, set idle circuit, set idle revs, set timing, drive. Ought to be about an hour.
That said I still have a lot to do.
Here's a few of the car with the center-section back on for trial fit of roof scoop ducting. Fits good. The last one you can barely see the scoop exit onto the air-filter. The others are of the ducting up in the roll cage and the first two are the side scoop expansion with the bodywork back together. This is what a SLC looks like without a rear window.
