Source for custom wiring harness?
PeteB
Well, I talked to my tuner today and the problem I'm having with my throttle is most likely a bad wiring harness. So I'm thinking instead of ripping out the entire GM engine harness, maybe I could just replace the wires from the ECU to the pedal and to the throttle body. Anyone know a good shop that could build me just those harnesses?
PeteB
Thanks - that's the place I was looking at. I'll call them and see what they say. If I do replace the entire harness, it won't be with another GMPP one.
PeteB
I would de-pin those particular connectors first. It could just be a bad crimp.
I will de-pin and take a look, but I'm not hopeful it's going to be that easy. It's an intermittent problem that didn't show up until I had over 2000 miles on the car.
I had Current Performance make a complete custom wire harness for the engine compartment. Very pleased with the work, only limitations were on my end. Had them make the FBW throttle "cable" too.
PeteB
Got a new pedal harness from Current Performance. Only $30 + $10 shipping! Hopefully this will solve my throttle issue.
