Stephan E.
Hello Johan,
That is exactly the question which drove every ITB user into insanity. There is no free lunch using this setup. It is race breed and requires rpm to properly function since there is not enough vacuum until about 5000 rpm for a MAP and the TPS only was always assuming a constant airflow at a certain throttle position but did newer knew the actual load. A real issue in the past but modern ECUs such as yours allowing Alpha-N and Speed density to be combined and to kick in at certain trigger points. Also atmospheric pressure and temperature are now measured and included. The Holley Dominator is actually a good match in addition to the MegaSquirt. Both have short and long term self tuning capabilities and dedicated ITB functionality. Nothing for a parade or 1700rpm in sixth gear on the highway. You trade lightspeed throttle response, power increase, sound and looks for driving comfort. My Audi V8 gear ratio will go very well with it.
Stephan
Stephan
