12.5mm (1/2") rivets will be fine
Rgds
Andy
Rgds
Andy
Trev,
don't worry about the dent, it will be fine. To fit my pipes (which are slightly larger diameter aluminium), I had to add a couple of flat spots so that they will fit under the handbrake cable bracket, so a small dent, although annoying won't have any impact on there performance
Regards
Andy
Also here are a few pictures I forgot to post showing the issue with the coating on the underside of the chassis and the rust coming through.
Trevor --
I'm curious to know what the coater's explanation was for that. To me, as a novice powder coater, that looks like the guy holding the gun just wasn't paying attention, nor did anyone look closely after it cooled off. Or was it not obvious until some rusting set in?
The coaters said that what happened is that when they started my job they think the static setting on the gun wasn't set the the right level. They say the corner areas where 2 sections of the chassis meet needs higher levels of charge to take which is why it's patchy.
Tell me,,,, does anyone think I am over the top on this?
Trev,
Man....... you are being a lot cooler than I would have been if my chassis came back looking like that. I have to say their quality control is sorely lacking.I hope this isn't costing you more money! This redo should be gratis in my opinion. No painter worth his salt would ever let a piece of work go out the door looking like that. Pics no. 1 and 3 tell the story, and there is no excuse for that result except to say that it was the first piece that individual had done in their life. I think it says the chassis was never inspected before it went into the oven. Is this an accredited company? I would think you might have legal recourse on that work if it isn't corrected. Surely for them to be doing chassis they have a rotisserie for getting every side and part of a big project. I think it is inexcusable.
Having said all that, I hope it comes back completed and to YOUR level of satisfaction. I think I would make an effort to visit the shop when they have finished the work this time and do a personal inspection of the job, and I wouldn't take it home til it is done right 110%. They should be embarrassed over those results. I think I would quiz them over what they intend to do to correct this before they start the repair. Oh, and I don't think it would be too much for them to put it in writing.
