And brakes have been happening. running brake lines, new calipers, new master, etc are covered in previous posts but suffice to say that takes a lot of time. Then dealing with the inevitable leak, remaking a line, and so on. But, as of now the hydraulics are all up and working.
Rear underside line with Cobra rear splitters.
And brake bias valve for the rear. I suspect she'll be the only girl around with one of these on her car.
The parking brake was a pain in the ass. What I ended up doing is getting some cheap $30 for the pair 87-93 parking brake cables and cutting them up and resizing them for this fox body.
I'd start by cutting the end off that connects to the parking brake handle tee. Then pull the cable out of the sheath. After that remove the metal piece there on the end of the sheath by cutting it off then using pliers to unwind the sheath thereby providing a sheath. The sheath gets cut down to fit the fox, the end is crimped back on using my huge crimp tool, then the cable is run back through the sheath. New fittings for the ends from McMaster are crimped on and done - $30 cables that fit great. Done.
Routing of cable using leftover SN95 parts.
And once all that was down the nice ally driveshaft got bolted up.
