CAV GT40 gen 1
Hey fellas nice to find a GT40 forum we are currently putting together a gem 1 CAV we are pretty close with it just trying to get some feedback on shifter setups. Would love to set up with rods but seems like the hot set up is cables let me know what it guys think. Thanks. I’ll post pictures of our project here shortly
Welcome to GT40s.com ...
Please go to your user control panel and change your user name to your REAL NAME as you agreed to do by our rules when you registered.
Thank you.
Hello Leon, very nice build! Did you custom build these headers/collectors, or you managed to source them somewhere?
I have CAV #22 with a cable setup, but a friend of mine has a scratch-built GT40 with linkage.. I definitely prefer the linkage setup, and looking to see if I can fit that into my CAV chassis. not going to be easy though i'm affraid.
Bill Kearley
Leon, how are making out with your shift linkage? Jasper, I'm also interested in going to a rod shift linkage. I almost had it worked out on paper before I went with cables. I think it's quite doable with the RBT and a left hand drive.
Doug S.
Thank you.
Randy, I'm trying to change my old user name (YerDugliness) to my real name, as we are encouraging all users to do. I can't find my control panel. Can you give me directions to get there and change my name to comply more fully with the forum practices?
Thanks....so sorry to be so dense about this, but the further from the answer I get the more confused I get.
You’re fine. The YerDugliness is the ID that the forum software knows as your logon ID. Just like mine is Big-Foot. These are the logon names we chose and that’s fine as long as the User Name that appears in your messages and threads is a derivative of your true “real” name (we’re both in compliance).. I can check to see if we can change logon ID if you wish.
Doc Watson
You can get the castings for a solid shift assembly although I'm not familiar with the CAV chassis. You would need to obviously route the shift through the bulkhead and although a solid shift can be used on the central tunnel its easier to mount the gear stick to the right of the driver (in a RH car)
Here is mine. It is cable but heavy industrial push/pull on a ZF transaxle.
Here is a pic at the transaxle (ZF inverted). Not on my car but same Olthoff Racing setup. My car is left hand drive and this setup works great. If I had right hand drive I'd probably use the rods like the original cars.
So: The million dollar question from my side.
I have a RHD CAV gen 1.. but i'm importing it into a LHD world (The Netherlands).
What would be best for resale value on the global market place: Keep it RHD and convert to 'correct' RH-shifting? Or convert to LHD because a bigger market might want to drive in a 'normal' seating position..
just keep all the parts, have photos of both set ups, then its got the biggest market possible. Assuming your not removing any mounting brackets and that any holes can just be plugged with gromets
So most every market outside the USA would want RHD. RHD is growing more interest in the USA also as all the original GT40 Race Cars were RHD. If I had a RHD GT40 I would not go through the expensive and hassle to switch it unless my country required it.
I will second that, also driven mine in France numerous times and not noticed any major problem driving it from the “correct” side
