You folks that have tracked and raced your GT40s what sort of chassis setup are you using? That is, front and rear camber, toe settings, caster, and spring rates? Sure, the discussion could bog down with "the XYZ chassis has this setup and the ABC chassis has this setup, so you can use XYZ for ABC" but in general, the cars are far more similar than dis-alike.
At first shot I would probably attempt -2 degrees neg camber upfront, with a tiny bit of toe out for crisp turn in. In the rear maybe -1 degree neg camber and zero toe. Probably get as much caster as I could in the front. Not sure on spring rates except that I felt the RFs I've driven were too soft stock and need to be stiffened. Also seems to be true for a couple of CAVs I've seen on track, got some body roll going on I'd like to avoid.
Anyone have any real life experience and settings to share?
Ron
Ron
