Hi Rod,
There are no inserts, I did consider it but stainless and alloy are not good friends and there is nothing that require's repeated use, hence the use of studs not bolts, on final assembly the studs will be loctited in. 8.8 is more than enough with the size and number of studs being used, they are all coarse thead in the alloy and fine thread for the nuts.
As for production, Thats not a reality but "Built to Order" individual units will be availible. This one which is actualy the second unit is realy the "test mule" which is why John has got involved with me on this, I was going to test in my car but it is still a long way off and Johns car will be running quite soon.
The cost will be on a "By order" basis and dependent on spec, obviously a Toploader spec will be less than a Jerico and the type of 9" used also varies in cost, There will be the QC option also which adds to the base cost so it is hard to say it will cost "X Dollors" What I will say is it will be well south of the $30k that is a Hollinger or Albins.
If people are interested, just ask on here.
Hope that answers your questions, BTW I'm not a vendor, just a builder but if you want stuff PM me.
Sorry Rod, Time Frame?? six months, Now I have all the patterns, spec's and machine shops, it's just a case of lining it all up and putting it together. There are some changes to the main case that I'm going to do before another build and there will be a 5 speed option as well if its wanted. There will be a 35 spline large CV axle option and Uprights to suit.
Cheers Leon
