Eric's SLC Project Code Name "Grifter"
Several people have buried there fuel system in there. As Fran says, it is a difficult place to service. I also don't like the pump essentially inside the cockpit. Even allowing for the tank cover behind the seats, I still don't like it there. I built a mounting plate and located all the fuel system stuff on the chassis rails along side the engine on the outboard side in front of the rear wheels and right in front of the drivers side scoop.
I made it so the entire plate could be removed and the components serviced on the bench.
See my build log, SLC24 Howard Jones. Welcome aboard the SLC train! Anything I can do just drop me a PM
Throw it away and get another. It's not worth the time to fix and it will more than likely leak anyway.
http://www.ebay.com/itm/like/350589823360?lpid=82
A bit of advice kindly given.............. I spend twice as much time thinking as doing and I still frig things up from time to time. Slow down and enjoy the journey my friend.
Residual Pressure Valve Check Valve 2 lb for Disc Brake New 2lb Pressure Valve | eBay
Thanks Howard, any and all advice is well taken and greatly appreciated :)
PeteB
How did you do that out of curiosity?
Squeezed it with vise grips until it cracked.
For the fuel pump accessibility, I cut the cover panel on the inside of the cockpit so I can remove the cover in front of the fuel pump area. Still will require taking the seat out and pulling the carpet back, but I can get to it if I need to.
Michael Fling
I too made a plate. The high pressure pump, fuel filters and regulator are on one side, and the low pressure pump is on the other. The battery is located in the front trunk area.
I just broke it... No luck... Stuck in there.
Thanks everyone for the help. It's always appreciated. The wisdom of others isn't lost on me! :)
I had to have a 'win' last night so I put together the pedals and master cylinders according to Allan's description of the 3/4 to the front and clutch and the 7/8th MC to the rear brakes. Cut the rods down to a comfortable position for each pedal, assuming I'll be blip-shifting, hence the brake pedal higher than the gas pedal.
Congrats! I'd like to arrange a time that is convenient for you to buzz over and take a look at it. My project is not going to happen until next year so would love to stop in and check yours out from time to time; even help as needed.
Sure thing CHuck, did you send me a PM? I can't remember, stop on over :)
Added some minor things, all stuff that has to get done. Still have yet to find a good way to get the tape residue off without some hassle. Oh well... Maybe it just takes more elbow grease.
Finished brake lines to the calipers. Had to remove the caliper on the rears to get the banjo bolts in, not a big deal.
FInally got her up on jackstands to do some of the more important work:
Master cylinder reservoirs. I was pleasantly surprised at finding pre-drilled holes for these on the drivers side. Made this so dang easy.
Buttoned up for the night
PeteB
Yes, except for the fact that there's a support rod that goes right where the pre-drilled holes are for the most rearward reservoir...
More updates:
Got all the brake lines fitted and attached firmly to the frame. Coolant lines are in place and most of the frame stuff is done, including the fuel system, just a few little things here and there until I can get an engine. W
I will be moving on to the AC unit and install next.
Today just seemed like a good day to work on the body.
The first cut is always the deepest!
Place ENGINE HERE:
Paint color test:
My son is finally old enough to really help daddy in the garage, here he is drilling and tapping his very first hole! :)
On the brake reservoirs I just use the brake ones, left the slave cylinder on the master cylinder, then the other brace would work. Putting fluid in from inside the foot area is easier then taking off the front end, I wish I would of put them all down there, might still do that when I take the body off this winter to finish the insides.
Your kid will have that picture for the rest of his days. One day when he is building his own ride (whatever that is in 40 years), he'll remember "My Dad did this to me"
LOL, I like the idea of having using my name as a curse word every time he compulsively buys car parts :D
