Thanks for the comments Jim, but this is just engineering, your car body is taking real skill to fabricate from scratch.
Sway Bars (Anti-roll Bars)
I really wanted to fit adjustable blade type sway bars to the GT40. Problem as always was space. I purchased the blades, bars and fixed arms from
Genesis Technologies Race Car Parts and Equipment. Pillow blocks for the bars were sourced elsewhere and are alloy with self centering bushes fitted in them, very nice units.
REAR
When I made the transaxle mount I left clearance between the mount and the transaxle for a bar. The modifications to the shock uprights also accommodate the sway bar bearing mounts.
The sway bars are hollow 25mm diameter. At the end of the "blade" arm above are bearings in the supporting tube that allow it to rotate and adjust the sway bar. These are pretty common units in race applications. I used a spline on the end where the bar connects to the rigid arm so the removal of the assembly is easy. The rigid arm was milled and bolted to bend it rather than heating it up etc. The end result is very strong and exact.
Drop links were turned up on the lathe and groved in the mill.
FRONT
The front bar was routed through the chassis to keep the space ahead of the footbox clear. The self centering bearings ensured the bar does not bind due to it being impossible to get both sides of the chassis parallel. Missing the brake cooling duct in all suspension & steering lock combinations was tough.
