Well I was up at 4 am this morning to watch Hamilton live winning the F1 drivers championship. That never happened! Now 19 hrs later I am feeling a bit stuffed and have decided to flag work on the car for the night and post a quick update.
I have been building the exhausts the last few nights. This is very satisfying as there is heaps of progress to show for a relatively small amount of work
I will do the dialogue tonight and post pics in a day or two.
The main chassis and rollcage is virtually finished except that the door hinges have to be fabricated and mounted on the front rollbar legs.
Front suspension wishbones have been built. Rears yet to do but with parallel links they are just simple straight tubes.
The front subframe to mount the front clip and radiator, and the rear subframe to mount the rear clip have been fabricated. These are bolt on for ease and speed of repair. Rear deck snorkels have been installed and both clips mounted and hinged
Most of the motor parts have now arrived from the various suppliers. So I have had a mate, whose specialty is NDT at a local aviation facility, crack test everything. All OK, but it pays to check!
Interestingly, his boss is a guy who who used to do my crack testing when I was racing Brabhams 35 years ago. So we're quids in there! Nothing like having mates in all the right places. In typical Kiwi fashion, always FOC
So I'm in the middle of the initial dummy assembly, checking clearances, determining pushrod lengths, deck heights etc before sending it out for balancing. No mates in balancing unfortunately!
The inlet manifold seems to have gone astray in the shipping though. Nothing special, only a secondhand Victor Junior off ebay. Keeping an eye open for another one, although it could well turn up in the next Stateside shipment.
Lim has almost finished machining up the alloy flywheel to take the 930 ring gear, 7 1/4 " triple plate clutch, and 928 front mounted starter. The starter is going to be mounted on the LHS of the motor on the rear motorplate/adaptor to free up the RHS for the dry sump outlets on the relatively shallow pan. The starter is going to be a tight fit so we have dummied up the rear section of the proposed pan in perspex so we can see where everything is before we make the actual pattern for casting the sump.
The hydraulic release bearing has been sussed out and modified.
The front motor plate has been fitted up as has the rear motor plate which incorporates the transaxle adaptor and I've started on organising the water lines.
We have just got the roughed out hubs and driveshafts back from stress relieving (One of Lim's mates this time!) before Lim does final machining.
Stripped the sideplate out of the spare 930 yesterday and measured up in preparation for making the billet side plate.
It's all go, heaps of things underway and half finished. That's the way it happens with a scratchbuilt, you start on something and it affects, or is affected by, something else and you have to nut that out before you can continue with the initial item. Ad infinitum. One day there'll be some real progress!
And then there's the simple issues like which sides do the hubs go on?:dead:
Photos soon.
Cheers,
