A very common question, which gearbox will hold and handle 900 HP without breaking.
Well I would have to say your best bet would honestly be the Ricardo, but since you would like to explore other options, I would have to then recommend that you go with a G96.96 which would be a GT3 gearbox. I would certainly recommend that you install a better pump and cooler with this gearbox, so in reality a GT 2 gearbox would be better as you would not need the pump and cooler from the GT 3.
Excuse me if I seem clueless, G96.96 = GT3 = GT2 has better pump & cooler? I'm not opposed to the Ricardo idea it just seems like such a huge and heavy piece at first glance I'm hesitant to want to use it.
I have one of these that could be modified to handle the kind of HP you are talking about. We have seen these handle 1100HP in the Mosler cars, and should be able to handle 900 HP just fine for yours.
I would further recommend that you have the internals Cryogenically stress relieved as well as REM Micropolished to reduce the friction created in the gearbox, as well as give the internals the best strengthening options out there. This will allow for cooler operating temps, as well as less driveline loss.
Here is what you should consider though as this would not be a cheap option.
G96 gearbox with upgraded OS Giken Limited Slip Differential, (the only differential that will handle this kind of HP in my opinion) Inverted, with Cyro/REM, Cooler in and out fittings installed, Taller Porsche Motorsport 5th, and 6th gear sets, with gear oil.
Price, you better sit for this one. $17,875.00 plus shipping.
Benefit of knowing that you wont die at 200 plus mph due to gearbox failure- PRICELESS.
haha, yes I would prefer not to die attempting this, as my future wife might not like this idea. Price is really not a huge deal, I mean I'm going to wind up paying around 30k for an almost rolling chassis. Not to mention motor costs and all the other small things that will incur since I plan to attempt something wild.
There are some less expensive ways of building this gearbox, but I would not recommend them if your goal here is to actually run this car to it's maximum speed, which I am not sure is aerodynamically possible, but you would know more about that then I do.
Regearing this gearbox will give you a top speed at 7000 RPM with 335/30/19 tires of 209.292 MPH
I'm assuming in 6th gear? final drive and 6th ratios?
I hope that this option is at least helpful in the respect of showing you what it would take to build a gearbox to do what you are asking it to. While the Porsche option is lighter, and just a bit smaller, it is a pretty expensive option, one which not too many wallets can endure. LOL.
Definitely helpful, how much weight are we talking here? Shaving off weight anywhere I can would be nice.
Let me know if you have any questions that I can help you with on this one. We do a lot of these gearboxes so I know quite a bit about them.
Comparing apples to apples here though I think you can see that perhaps the Ricardo option is not as bad as it once appeared. I am sure that Fran Hall can help you with a Ricardo, should you decide to go in this direction, but I am sure that you already knew that.
To be honest I haven't done a whole lot of research just yet into upgrading and whatnot available for the Ricardo. It's definitely on the list of things to do along with your suggestions.
Warmest Regards,
Erik Johnson
GBox Sales Manager
(303) 440-8899 work
(303) 895-4828 cell
