Well the work continues on. I have moved my focus to the front clip for a while (I have a small issue on the back so I'm doing the Ostrich thing) I have started the fence on the left side now and the front panel/wind screen surround. The fence is pretty simple, just cut it to the right shape glue the edge with PVA and support it while it dries once that is done radius the inside with some bog. The front panel is a little more complex, it has to have the bottom rounded to drop at the bottom. I did this by making ribs inside then scouring deep lines in the sheet so it would bend easier and glued it in place. then the wind screen surround has to be shaped as it goes back to match the door which has a 45 angle side so I made some ribs and curved it back and attached it so it would hold the shape then there is a second piece on the inside where the actual screen will screw to. This will create a lip so the screen will be flush with the outside panels. The next step is the panel that goes down the sides and across the front where the clip will rest on the alloy tub. I have done the front and left side which is quite a bit of work as it has to fit the shape of the fender and the ribs inside as well as over the top rear link. The pictures should show what I've tried to explain.
Cheers Leon
Cheers Leon
