I have not posted for some time so I will update.
I cant remember the order of some of the work so I will just put it up in what ever order.
Confession time
I had already built the front uprights but was not happy with my wheel offsets on the front and decided that I cant live with it.
The off set was due to reducing scrub radius, longer suspension arms and several other things that I decided that I was looking for.
Keeping in mind that I educated myself as I went along and was prepared for some learning curve, I don’t regret any of it other than I spent more than I had to.
A friend walked into my shop when I was rehashing this and he said “WHAT ANOTHER SET OF UPRIGHTS”
My reply was when I am finished I will be better at it than you.
The front wheel looked to flat.
With the 16” wheels I was also not happy with the lack of tyre in the arch.
I made a decision and an expensive one to redue the wheels but this time I would make them myself to have more control over the end result.
The main issue was trying to steal space from somewhere as I wanted to retain the arm length, this came from the disk offset.
The original disks I used had an 83mm offset 300x 28 thick aprox.
The disk I selected is 51mm offset 300 x 30 thick, this meant the Brembos had to go due to disk thickness and I can not fit them under a 15” rim.
The 32mm that I gained I moved the wheel flange in by 17mm and the disk further out by 15mm, as I was chasing a better ackerman angle and needed room for the steering arm.
The upright is 6061 t6 I made it 20mm taller to use less spacer for roll centre adjustment, I incorporated the calliper mount , upper ball joint mount is removable and keyed into the main section of the upright so the bolts don’t take all the load under brakes.
Steering arm is separate and is held by the 2 lower wheel bearing mounting bolts.
The assembly is 1 KG lighter than what I had, also A massive reduction in components.
I had 13 individual pieces to be welded on the original and 4 bolt on components on the new that is a win for me as it keeps it simple.
