Kyle,Looking for ideas/part numbers for the LS drivers side water pump hose. The 90 slim hose with preferably a long leg.
I used this from Pegasus Racing.
It is definitely a very tight fit at the front of the engine.
I used a easyguard keyless pushbutton with the Coach-1, very issues to get wired up using the manual from the system.
Perfect thank you. Ya I elected for the coupe 23 board. No windows or locks on the car, just door actuators. I also didn’t feel like I needed the auto dimming lights etc.Yep, that's me. I'm traveling for work today, but should be home in a day or two and can double check my wiring for you. It looks like you have a different coach board than me, however I'm sure it works the same. Most of the coach switches are ground based, but those for the ignition switch are 12+, so you can just run the Acc, Run, and Start wires from the EasyGuard into the Coach.
The other white connectors, Horn, Low Beam, Hi Beam, and Neutral are ground signals. I think the Fan Hi is a 12+ as well.
I saw this post but it never really resonated with me until now. Maybe I can commission him to make some more, otherwise I’ll have to craft up something else.Kyle,
Making good progress.
Check out Kurt’s post #119 for inboard seat brackets that move the seat over as much as 1.5”:
Kurt H (hoffkm) SL-C build thread
Yay, the wiring is complete (for now) or at least as far as I can go for now. Many builders have run wiring on top of the footbox beneath the dash panel. I chose to run all my wiring inside the footbox so I can still access it with the dash panel in place. This was not easy for me to get to...www.gt40s.com
That will be my next item to order, completely forgot about those things, I guess I need them!Kyle
During my build I shoved my seat inboard but forgot to consider seatbelt hookup. That forced me to go back outboard some. Hopefully that is a consideration in your design.
I might have to do that Dan, thanks!Kyle
Just a thought on the shifter. I bent my shift rod about 20 degrees aft so I could move the shift box forward and to give my hand more room when shifting forward. I kept hitting the dash with my knuckles. Again, just a thought.
