Just got back from Scotland, so not much done in the last week or so.
Air conditioning engineer filled and set up the air con system today.
We fitted the new dryer unit, Vac the system down first for 20 minutes then charged with 134a refrigerant gas.
The air con switched on and after the squealing drive belt was re-tensioned the system started to get colder. the screen started to get condensation on and the tempreture dropped.
The trinary switched operated the rad fans and all worked a treat.
Leak tested all the joints....Job done.
Monday the engine builder is coming to fine tune the engine.
The alarm engineer hopefully next week to test the system and sign the Thatcham approved paperwork.
Had a bad connection on the brake light wiring which is now rectified and the brake lights are working.
